Help a bro out!!
By grcplaya · Nov 24, 2007in Hacks/Mods💬 11 posts👁️ 1,558 views
Posted Nov 24, 2007 · 05:01 UTC#1
Ok, got my april z2(today) downloaded the hack ware, for some reason it would not download to the Z, I check the disc put it back in my computer says bypass on disc, so now I'm like WTF, so I go ahead and do the bypass anyways, grounded the wires took around the block for like 5min. its working, NOw I'm WTF, shouldn't it of not let me watch movies? it does say version 2 on the hardware of the z2
also does the Ipod module support my iphone. it does bring up my playlist but I get no sound.
Help a bro out!!!!!!!!!!
Grcplaya
oyea the reason Ihave a z2 cuz some fuc stole my wifes z1 so I took mine out put in car so the kids would have the home theater again.
Posted Nov 24, 2007 · 07:38 UTC#2
DOH!! had the cable backwards on the ipod module. its working now
but still need info on the bypass, anyone.
Posted Nov 24, 2007 · 15:32 UTC#4
Follow the instructions here: http://www.sminntech.com/z1flash.html#newbypass
If it doesn't work, you either did it wrong, or didn't burn the disk right[/quote
Ok, must not of burn right. but shouldnt I be locked out from veiwing movies, even if the disc didnt get loaded up?
thanks for your help. just making sure that I do need it..
GRc.
Posted Nov 24, 2007 · 19:34 UTC#5
Sometimes it takes time for the nav to calibrate fully before it cuts off video right away
Posted Nov 24, 2007 · 20:08 UTC#6
ok cool, I burned the CD again just to make sure the other one was faulty.
the first copy I did when I loaded it up all it said was a Cd rom was inserted. I notice the only way to burn the download is on data. is this correct?
I will try it again a couple hours.
thanks.
Posted Nov 25, 2007 · 00:59 UTC#7
well i tried it again, and still nothing, I've must of ripped the cd 4X
am i ripping it wrong or what, tonight I will drive it for little longer see if I get locked out..
GRc
Posted Nov 25, 2007 · 03:40 UTC#9
MS, tried that same deal, when I pop the disc all it says cdrom inserted.
well I'm done for the night, even tho I can still drive around an able to watch movies. I will leave at that, unless something finally decides to not to work.
Posted Nov 26, 2007 · 04:59 UTC#10
well I was on the road for 3hours today, I had no problems viewing movies, maybe my deck doesn't need the upgrade.
grcplaya
Posted Nov 30, 2007 · 05:27 UTC#11
hopefully you are all set.
