2008 Honda Element VSS
By dabury · Nov 24, 2007in Hacks/Mods💬 1 posts👁️ 991 views
Posted Nov 24, 2007 · 19:14 UTC#1
Hello,
I'm trying to determine if indeed a 2008 Honda Element has a VSS and if so, where can I pick it up. I've read a couple of posts with different answers. Is the wiring different on the 2007/2008 elements? We could not find blue/white striped wire at the ECU like they say is used on the earlier elements. I've read that maybe the new models have changed and the speed reference should be taken from the abs like the Honda Ridgeline. We have installed the AVIC-Z2 and completed the 2-wire bypass. We tried to trace a wire from the transmission tach generator (I think thats right) and take the wire from the speedo cluster but when we look on the nav touch screen, it shows that we're not getting counts. The system seems to work without the VSS for now but we've only driven approx. 100 milses. Any and all help will be most appreciated!
Thanks,
Doug..................
