Avic N3 GPS Problem
By MylesG23 · Nov 28, 2007in Problems/Troubleshooting💬 1 posts👁️ 659 views
Posted Nov 28, 2007 · 12:25 UTC#1
Hey guys, sometimes when I start my car and start driving the MAP wont move. like, it will say i'm at home or something, then other times it's fine.
Does it have anything to do with the speed pulse and what not?
another problem is. Voice Guidance isn't working...and it won't automatically re-route the route if I go off Track..
and I connected all the wires to the Speed pulse, and it says "This feature is not yet available" or something..
_______________________________________________________________
I'm using my N1 wires. I did the bypass with the switch. The guidance volume is at 75% and says' Volume will be set at this level' so I know that part works.
Could it be the bypass?
OK, and on the Dynamics screen, it says the Voltage is 56 and a 2...
________________________________________________________________
Ok, so I took out the N3 Brain, and used the N1 brain, and everything worked.......
The think is, the Tuner on the n1 brain doesn't work.
And the n3 brain is fairly new.. I don't know what's up
