D3 wont turn off!!!
By utkaviator · Nov 29, 2007in Hacks/Mods💬 5 posts👁️ 957 views
Posted Nov 29, 2007 · 04:28 UTC#1
I just installed my AVIC-D3 and it will not turn off when the key is turned to ACC off. I have checked and rechecked the wiring. I have unplugged the wireharness from the unit, placed a current/light meter on the ACC pin, and cycled the key from OFF to ACC and it is delivering the proper power relative to teh ignition switch. Could there be a problem in the unit itself or has anyone seen this before?? PLEASE HELP IF YOU CAN! thanks!!
Posted Nov 29, 2007 · 04:51 UTC#2
Posting in the Z-series hacks and mods section is a good place to start :roll:
But let's be serious. You screwed up the wiring. Switched IGN and ACC wires. Buh bye!
:arrow:
Posted Nov 29, 2007 · 04:52 UTC#3
year make and model of the vehicle would also help.
Posted Nov 29, 2007 · 19:57 UTC#4
2007 Subaru WRX
That was my thought too...unless the AVIC input harness came with them backwards then I'm not so sure they are switched. I put a light tester to the ACC lead going into the D3 and it is alive when ignition is in ACC. I am wondering what is the correct location for the ACC and Battery wire in the D3 harness itself so I can double check and make sure it was assembled properly.
Also, how does that explain the clock remaining on?? would the clock be feeding off the switched wire?? I know that probably doesnt make sense but im losing sanity :) Thanks for your help! and you are completely right, wrong place to post...sorry :?
Posted Dec 02, 2007 · 04:54 UTC#5
fixed it!!! re routed grounds so i had a few different chassis locations, and pulled power off the ACC wire instead of the Battery wire for my Sirius...those seem to have worked like a charm
