Then you get some brain in the front seat of the hummer
By MylesG23 · Nov 29, 2007in Problems/Troubleshooting💬 10 posts👁️ 1,442 views
Posted Nov 29, 2007 · 05:22 UTC#1
Ok, well I figured out that my N3 Brain is messed up. When connected it wont recalculate route nor give voice guidance. Also on the Dynamic Screen is says Voltage is 256V...and gps is always off course... but other than that everything works.
temporary solution.
I took my N1 Brain and connected that and everything is working great, except my turn signals don't work.. and the AM/FM tuner doens't work.
Should I send it to Pioneer?
Posted Nov 29, 2007 · 23:36 UTC#2
if its under warranty i would.
if not find a pioneer warranty center neaar you and talk to them and see if they can help you out, i know theres one here in greenville, sc called Masters Car Audio.
Posted Nov 30, 2007 · 00:28 UTC#3
Turn signals shouldn't have anything to do with the radio. You sure you didn't disconnect a wire by accident?
As for the tuner, did you plug in the antenna cable when switching units? And does your car have a powered antenna that needs to be hooked up?
Posted Nov 30, 2007 · 01:47 UTC#4
Well I sent my n1 over the summer, and they told me the tuner needed to be fixed. And now my heat doesn't work.....
I donno, I just want to use the N3 brain. but that's messed up
Posted Nov 30, 2007 · 01:53 UTC#5
Your heat and turn signals are different problems. Take it to an installer familiar with your vehicle and they should be able to fix those two
Posted Nov 30, 2007 · 15:13 UTC#6
i had a similar problem in my wifes car last month, put the radio in and the heat stopped working, eventually i found that when i ran the wiring, i accidently knocked the cable that controls the heater loose, clipped it back in place and everything was fine. Like the previous guy said the blinkers and heat are totally different sysytems and do not interact with each other except as far as getting power. I would double check where you routed your wiring and see if you knocked something loose. The blinkers use a relay somewhere under your dash and its possibly knocked loose.
Posted Nov 30, 2007 · 19:34 UTC#7
i thought this post was going to talk about something totally different.
Oops. My mind is in the Gutter.
Posted Dec 01, 2007 · 01:55 UTC#8
I've had the system in for almost a year, the only thing I did was switch the N3 brain for the n1 brain.
Posted Dec 01, 2007 · 21:08 UTC#9
if your brain is nowhere nere your controls for heat and blinkers then you have an unrelated problem, unless you ran some new wirirng, or pulled on some wiring.
Posted Dec 19, 2007 · 16:22 UTC#10
I have the a similar problem. The hardware status says voltage 256 back signal nok and speed pulse nok. This is on an N3 brain to N1 headunit. Did you find a solution?
