I have a couple of questions. I just started trying to install mine and I am having a couple of problems. I got the navigation to work and it is great so far. But the audio seems to not be working for some reason. As far as I see, I have connected all wires correctly and securely. But I am thinking the problem might be coming from by attempt at bypassing the parking break. I pulled out the mute wire, inserted it in the hold above and attached it to the ground wire. I was thinking that the audio problem might be from me not pushing the mute wire in the upper slot far enough. My questions are:
-If that relocated mute wire isnt making contact with the HU, would that cause my audio to not play?
-I am using a metra wiring harness for the type s w/ bose system. Does anyone know which speakers the violet, green, grey and white plugs go to (front/rear left/right speakiers)? I have misplaced my metra wiring diagram.
-Trying to track down the source of my audio problem further, the cables wires I have from the d3 that are attached to my metra wiring harness (and keeping the bose components intact) are battery (yellow), ground (black), ill (orange & white), 12 volt power (red). I didn't list the 4 plugs for the speakers, but am I missing anything? I have a solid orange wire and a gray/white wire for 'amp turn on' hanging free.
Thanks in advance.
