avic z2 motion bypass question
By 06gator · Dec 04, 2007in Hacks/Mods💬 3 posts👁️ 1,348 views
Posted Dec 04, 2007 · 14:45 UTC#1
I bought a z2 and currently have a z1 installed. The unit I had died and will be sending it in to get replaced and will be selling it. I upgraded to the z2 because I can!! Ok here's the question, I already have all the harnesses installed in the truck and shouldnt have to change them right? Also I have the 2 wire bypass done on the Z1 and was wondering if I can leave it like it is, and install the software after I hook it up. Basically, will it affect anything if I leave it bypassed? Then upgrade the software? It might not even need the software upgrade but I just want to check. Also anyone here with a 2006 gator or within this range have the rear view camera hooked up? I'm having a hard time finding the correct back up light wire in the harness. I know its black and pink but there are a couple wires in there that are black and pink...
Posted Dec 04, 2007 · 21:35 UTC#2
You should be fine...same hardware, easy swap. You'll know soon enough if you need the update cd.
Posted Dec 05, 2007 · 20:39 UTC#3
Nope didnt need the cd. I do need to update to the no freeze software though. I will keep a eye on it and if it freezes then in she goes!! Thanks!
