Looking for pics of a D3 in a 2005 Silverado........
By RED903L · Dec 05, 2007in Hacks/Mods💬 10 posts👁️ 2,272 views
Posted Dec 05, 2007 · 15:58 UTC#1
NEWBIE here....
Hope there's some pickup truck drivers amongst this group!! Thinking of buying D3 to install in my 2005 Silverado, but would like to see pictures first...before I make the plunge.
The existing factory system consists of a AM/FM/XM/single CD player with OnStar and steering wheel controls.
Would really appreciate any pics that you might be able to share, along with your evaluation of how the system looks and works.
Thanks in advance....
8)8)
Posted Dec 10, 2007 · 19:50 UTC#3
Here's mine
Posted Dec 20, 2007 · 21:24 UTC#4
I have an 04 Silverado with onstar/bose and xm ready but havent bought the xm tuner yet. I'll see if I can get some pictures up for you sometime soon. I still need to do some things to it but its been to cold here in maryland.
Posted Dec 20, 2007 · 21:29 UTC#5
when you buy your expensive harness to wire up your d3, make sure you run your own fused accy. wire from the ignition column. i know with the scosche modules they are known for only having a 6v accy output, so you have to run your own fused from column.
Posted Jan 03, 2008 · 18:31 UTC#6
Yankee,
Did you put that wallpaper on the unit??
Posted Jan 03, 2008 · 18:42 UTC#7
32 if the unit comes with a relay then thats not a problem. if it doesnt have a relay then you should wire one up yourself so u can use the RAP
(the acc power till the door opens)
Posted Jan 16, 2008 · 23:16 UTC#8
Heres mine in my 03 SS, I have had it in for 2 weeks and its great. Im gonna hook up my backup camera and VSS wire this week, other than that it went in easy as hell. The only problem I had at first was I forgot to hook up the remote wire to turn on the factory amp so my door speakers didnt work, but I figured it out. I also did the bypass mod, and I have the bluetooth adapter and Ipod cable... If you have any questions Id be happy to help
Heres what it looks like in the dark, I hooked up the orange Ill. wire like it said but it doesnt dim at night so I have to get back in there and hook it up some other way.
Posted Jan 16, 2008 · 23:34 UTC#9
hey turbo cop i have a 04 yukon , i got my d3 to dimm at night, this littleside audio shop hooked up the illum. wire into the light switch assembly over by the driver door and i belive u should have auto diming lights, my d3 dimming feature now works with the auto head lights.
Posted Jan 17, 2008 · 22:56 UTC#10
yeah I think I know what to do now, Ill try it next time I have the dash out which will probly be this weekend
