Help w/ Dodge Charger install
By SafetyLighting · Dec 08, 2007in General💬 8 posts👁️ 1,373 views
Posted Dec 08, 2007 · 18:07 UTC#1
I will start by apologizing because I'm sure the info is already mentioned, but I couldn't find it while searching.
I have a 2007 Dodge Charger, and am installing an AVIC-D3. I ordered the Factory Navigation bezel, the CHYAH05, and of course the D3. I need an antennna adapter and what else to complete the install? I am holding off on the steering wheel controls for now. I called an install shop and they tried to sell me a Metra 76-504 amplifier bypass, ???.
Thank you for all the help guys.
Posted Dec 09, 2007 · 01:10 UTC#2
goto crutchfield.com and enter your vehicle w/ factory navigation and it will tell ya what ya need...do not get the amp bypass harness because it will not provide you with the reverse signal, speed signal or parking brake signal....you really need the chto-01 even though it cost more
http://www.crutchfield.com/S-KENcTVbqdn ... &s=0&cc=01
and if you want to keep your factory steering wheel controls, your gonna need a
http://www.crutchfield.com/S-KENcTVbqdn ... i=127SWIPS
and a
http://www.crutchfield.com/App/Product/ ... =127SWICAN
this is my jeep commander install which happens to use all the exact same parts since its made by chrysler also..
http://avic411.com/forum/viewtopic.php?t=11702
Posted Dec 09, 2007 · 03:33 UTC#3
Thank you very much.
Posted Dec 09, 2007 · 03:55 UTC#4
depending on if you have premium sound or not you may need that amp integrator harness, if not a standard chrystler harness will work, dont remember the exact metra part number, the one other harness gives you switched acc. power which is like 100 bucks, you can grabbed switched acc. at the cig plug, and meter the wire. that will save you some money there unless you have the premium sound
Posted Dec 09, 2007 · 05:16 UTC#5
c2r-chy best peice I've used for doing nav in chryslers. I've had issues with pretty much every other interface except for that one. Even works with the factory amp if you have one.
Posted Jan 06, 2008 · 23:48 UTC#6
Will using the pac unit connect the vss or give you the speed signal??
Posted Jan 07, 2008 · 04:11 UTC#7
Yep the pac module gives you everything at the radio too. VSS, reverse, illumination, parking brake (if you want to hook it up right, but who wants to do that), and interfaces the factory amp if you have one.
Posted Jan 19, 2008 · 07:15 UTC#8
Thanks I didnt do the install circuit city did it for me and when i had taken it out recently I had seen those wires were not connected. After I connected them it works a lot better. Thanks again..
