Hey Guys,
I have the TOSHIBA MK6034GAX hard drive out and ready. I also have a USB 2.0 IDE adapter from "Young Micro". I connected the adapter to the back of the hard drive and the only side that worked was the one that left out the left most 4 pins.
I connect the USB portion of the adapter to my HP Compaq nc6400 laptop running XP. The light on the adapter turns on and the hard drive makes a light noise like it's turning on.
However, the computer does not recognize that anything is plugged into the USB port. The USD IDE adapter info card says you don't need to install any drivers if you have XP.
Does anyone know what I'm missing here? How do I get the computer to recognize the hard drive so I can put the image on there?
Thanks,
Duke
