VSS wire location on 04 Maxima w/BOSE...Help!
By jroth142 · Dec 09, 2007in General💬 10 posts👁️ 1,187 views
Posted Dec 09, 2007 · 19:37 UTC#1
Can anyone shed some light on the location of the VSS wire in an 04' Maxima SE w/BOSE for me please?? In the process of hooking up my D3 and I have no idea where this wire is located.
Posted Dec 09, 2007 · 21:06 UTC#2
green or brown at the unified meter and a/c amp pin 26. its the first module below the display in the dash
Posted Dec 09, 2007 · 23:05 UTC#3
Thanks for the info. Unfortunately from what I can tell, it looks like pin 26 has a red wire in it. Pin 27 is green but not 26. I'm about 90% sure I'm looking at the right thing here but any additional help would be great. Thanks
Posted Dec 09, 2007 · 23:45 UTC#4
don't need the VSS wire if you cannot find it whe using the D3
Posted Dec 10, 2007 · 00:41 UTC#5
I was under the impression that the nav system wouldn't be as accurate if this isn't hooked up...is this right? I'm pretty sure I found the right module, just not sure on the right wire and pin location. Thanks
Posted Dec 10, 2007 · 00:47 UTC#6
Also, one other thing. Sorry for the dumb question but I'm assuming I want to splice into the wire going INTO the module and not going out? The only reason I wasn't sure on this is because I'm assuming that the SSV wire also go to the radio wire harness and I didn't know how all that wiring worked. So I just wanted to double check.
Posted Dec 10, 2007 · 15:16 UTC#7
just as accurate, well within a couple of feet
Posted Dec 10, 2007 · 15:17 UTC#8
also if you have never done one of these pay someone to put it in......you don't need the hassle of cutting the wrong wire etc.....
Posted Dec 10, 2007 · 20:48 UTC#9
I've actually got everything else hooked up and the unit seems to be working just fine. I just wasn't sure about the VSS wire. If it's really not that big of deal though, I may not even worry about it. Thanks
Posted Dec 11, 2007 · 18:22 UTC#10
So if the VSS wire is not hooked up will that mainly effect ETA's and things like that? Does the unit still track speed through the GPS or would I need to connect the wire for that too? If I could get a definate location and wire color for the VSS I think I could do the hookup up, just haven't found it yet.
Apparently my bypass isn't working correctly now though. After I started driving I got an error message about the parking brake lead not being hookied up correctly...suppose I have a loose connection somewhere : (
