D3 mapping off-track..wtf
By JayBeast908 · Dec 12, 2007in General💬 12 posts👁️ 1,735 views
Posted Dec 12, 2007 · 07:48 UTC#1
Hey everyone this my first post. I noticed on several occasions my D3 has mapped me on the wrong street. It would say I'm on street "A" when in reality I'm on street "B" not too far from street "A". Anyone know why this happens.
I have had to soft reset the entire unit every time is does that is there a solution for this problem?
Thanks in advance guys/gals
Posted Dec 12, 2007 · 08:04 UTC#2
How is your satellite reception when this happens?
Posted Dec 12, 2007 · 08:23 UTC#3
Im not sure I never checked my strength signal when that happens, I'll keep that in mind, but it really pisses me off when that happens on a $1000 unit.
Posted Dec 12, 2007 · 15:04 UTC#4
welcome to the world of shitty nav routing!
Posted Dec 12, 2007 · 15:46 UTC#5
Bad GPS accuracy and bad routing are two separate issues. My D3 has always had very good accuracy. I agree with whtcrxghst - probably a problem of satellite signal strength. And I'm guessing Jay's VSS may not be hooked up properly. Has nothing to do the D3's bad routing though.
Posted Dec 12, 2007 · 16:25 UTC#6
yeah this happends to me all the time.. i dont know how to fix it.. eventualyl it fixes itself.. ususally its right when i start the navi...
Posted Dec 12, 2007 · 18:30 UTC#7
I know it has nothing to do with the routing... I was just welcoming him to the club. :D
Posted Dec 13, 2007 · 07:41 UTC#8
New to all of this, what is a VSS
Posted Dec 13, 2007 · 12:46 UTC#9
vehicle speed sensor wire, usually hooked into your gauges in the dash
Posted Dec 15, 2007 · 07:47 UTC#10
My Vss is hook up correctly cause I can see my speedometer actual speed on the D3
Posted Dec 15, 2007 · 10:22 UTC#11
That has nothing to do with your VSS being hooked up correctly. The D3 can correctly gauge your speed better than the speedo in your car based on sat reception alone
Posted Dec 17, 2007 · 17:41 UTC#12
im also curious - where is your gps receiver located?
EDIT - just a note - i live in chicago (plenty of buildings and what not blocking line of site) - ive only had that issue ONCE and that was when i merged onto the expressway from a street running directly parallel - as soon as i merged to the furthest lane, the nav corrected itself - im guessing its a sat reception problem (as others have indicated)
