Please HELP.....this is driving me crazy.
By wander2166 · Dec 12, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,086 views
Posted Dec 12, 2007 · 22:51 UTC#1
I had the Z-2 installed by an experienced installer.....He did the two wire bypass. After he installed it , everything seemed like it was working fine. But after about 1/2 hour it would not let me view a DVD while driving. I then ran the bypass cd thinking this may help. Once again it worked for about 1/2 hour.
The installer came over took it apart and found that everything was hooked up like it was supposed to be.
We ran the new firmware update. Ran the bypass cd again then reset the Z-2.
Any suggestions would be greatly appreciated.
Anyone in the NY westchester area that may be able to look at it ?
Thanks in advance for viewing and for your help.
Brian
[email protected]
Posted Dec 12, 2007 · 23:00 UTC#2
bad connection on one of the 2 wires. Odds are the moved wire isn't fully locked into the harness.
Posted Dec 12, 2007 · 23:30 UTC#3
Dang...all the regulars have ~4k posts now. And here I am working on my first thousand.
Posted Jan 06, 2008 · 13:33 UTC#4
If you hadn't changed you're screen name you'd have over 1k by now. Better step up the postwhoring.
