Ill be getting a D3 next week. I want to install it right the first time. Might as well run the amp wires, mp3 player connection, xbox 360?)vide My mp3 player a dinosaur (creative labs noman zen xtra 60 gb that I've had for 3 years now) and it's time to upgrade. I will not go with a FM transmitter. I want a one-cord/connection solution that will play my mp3s and video on the AVIC as well as charging it. I hate ipods and want to go with an 80 gb zune. The ipod is so tempting with the accessories, but I've read the Ipod interface is retarded on the Avic and videos cause a problem. I've done a bunch of searches and know there are ways around those problems, b ut its annoying to have to do those added steps. It seems like the easiest way with the Zune is using that $250 car kit from iME - (http://www.imedock.com/zune.htm) Thats the same price as the friggen zune so f that.
I'm thinking I might be able to get a home AV kit to work.
a. If I get the 80 gb unit, do i have to get the AV v2 kit for 80$
b. I can see from the picture on Amazon that you connect a usb cable to the wall ac adapter to get power.
c. Instead of plugging the USB cable into the ac adapter, could I use something like this: http://sewelldirect.com/Zip-Linq-USB-Po ... ighter.asp -- a basic cigarette lighter to usb adapter ~$10. I'm going for cleanliness and want to hide all the wires so I'd only have the dock visible. I'd add a cigarette lighter behind the dash and run the power to that; run the component wires to RCA's in the back of the deck and call it a day. This will hopefully eliminate a power inverter and making it super easy to hook up and disconnect the Zune.
I'm sure I'm not the first person to think of doing it like this, but I haven't seen any posts mentioning this. I'm a noob, can someone tell me if this idea has already been shot down? Thanks alot.
