Posted Jul 22, 2006 · 03:52 UTC#1
Just found out the dang canpulse adapter is $200 to interface for VSS>
Yes it does, everything works perfectly without the VSS wire. The VSS wire is just for accuracy when you lose satellites, i.e. tunnels, overhanging trees, big cities, etc. I say if you live in an area where you frequently lose satellites then it would help, but otherwise it’s not necessary. I’ve had the d1for almost a year with no VSS and now going on 2 months with no VSS on the Z1... no problems at all.Anonymous said:without it i don't think that 3d hybrid mode will ever be avail. and calibrated.. I could be wrong, but i think so
tjdehya said:Yes it does, everything works perfectly without the VSS wire.Anonymous said:without it i don't think that 3d hybrid mode will ever be avail. and calibrated.. I could be wrong, but i think so
Oh so the one i am seeing now is just the simple one, does the other one look much cooler.... i guess i will go looking for the VSS wire then.... you know i have to have the cool stuff :Dducatiboy said:tjdehya said:Yes it does, everything works perfectly without the VSS wire.Anonymous said:without it i don't think that 3d hybrid mode will ever be avail. and calibrated.. I could be wrong, but i think so
Well technically "anonymous" is right, without the VSS you will not get the Z1 into 3d hybrid mode. Best the 3d calibration will get to is "simple hybrid" or something like that. It will never "calibrate" fully without the vss wire.
