Questions about AVIC N2
By executioner · Jul 22, 2006in General💬 5 posts👁️ 1,534 views
Posted Jul 22, 2006 · 05:19 UTC#1
ok I went ahead and bought the AVIC N2. Only problem is it has no disc with it. What would happen if after i install the unit i turn it on but have no disc for it. Will it work except for the navigation? It may have been rebuilt from the factory so it is possible at some point it already had a disc installed, how do i check this. Thanks
Posted Jul 24, 2006 · 07:14 UTC#2
Yes, it will work except for the nav
Posted Jul 24, 2006 · 14:21 UTC#3
Thanks. I did get it installed the only problem I have so far is it wont play dvds. I hooked up the parking brake the way it said and i even tried the bypass but both ways it says the parking brake is ont properly attached and only plays audio with a black screen. Any thoughts on this?
Posted Jul 29, 2006 · 22:06 UTC#4
Just connect the parking brake wire to the ground of the headunit and that will bypass the brake system wire!!!!
Posted Aug 04, 2006 · 02:11 UTC#5
Ended up that the head unit was bad as far as the dvd video went. Got another one and all is well.
