Help!!! No Power
By lorien86 · Dec 14, 2007in Problems/Troubleshooting💬 7 posts👁️ 922 views
Posted Dec 14, 2007 · 00:11 UTC#1
Help Guys!!!
Here's my problem.... I opened up my console to install a rear view camera into the D3. Then I power on my car and the D3 will not turn on... I pretty sure i have short circuit something because i plug in the original Saturn Outlook receiver and there's no power to that either?
My question is... Do you think i blew a fuse?
There's no saturn dealership where I live now, so do you think GMC dealership can deal with this?
Posted Dec 14, 2007 · 00:23 UTC#2
Check your fuses. Almost gaurantee one's blown.
Posted Dec 14, 2007 · 02:19 UTC#3
i'm hoping the fuses are blown too cause i installed it the other day without problems and i just unplug the receiver and replug too much... all this without disconnecting the battery cause i was lazy
Posted Dec 14, 2007 · 02:42 UTC#4
in thousands of installs, I think I've disconnected the battery twice. That was only because I had to disconnect airbag harnesses to remove seats.
Posted Dec 14, 2007 · 03:46 UTC#5
so you think it's the fuse? That's what i thought at first too, now i have to locate it though... probably gonna take it to a GMC dealership and see what they can do
Posted Dec 14, 2007 · 04:16 UTC#6
To a dealership....? To locate a possible burnt fuse...?
DIY man DIY.... :roll:
Posted Dec 14, 2007 · 06:40 UTC#7
Open the manual, look up the fuse box location, pull out the radio fuse. The dealership will charge you like fifty bucks for two minutes of work replacing a 50 cent part. Or a free part, if the fuse box still has any extra fuses in it.
