Z2 and 10 nav traffic
By 07on20s · Dec 14, 2007in XM/Sirius/HD Radio and Traffic Receivers💬 3 posts👁️ 1,101 views
Posted Dec 14, 2007 · 06:29 UTC#1
It was working during install then all the sudden it says check antenna but there is nothing wrong with the antenna. Can the xm and Sirius be next to each other on the roof. So i don't even get the channel 1 like i was before any ideas
Posted Feb 03, 2008 · 00:45 UTC#2
Antenna's can be next to each other without hurting signal.
If you're not getting Ch1, it's probably a connection issue. My first guess would be the XM satellite antenna came loose.
Posted Feb 03, 2008 · 14:24 UTC#3
IF it says check anttenna then it's 1 of 2 things.
1. Antenna came unplugged (doubtful since it locks in place)
2. The wire inside the antenna cable is broken, and the antenna must be replaced (more likely).
