AVIC-Z2 VSS 2008 Taurus
By crown · Dec 14, 2007in General💬 6 posts👁️ 1,693 views
Posted Dec 14, 2007 · 14:38 UTC#1
I am installing a AVIC-Z2 in my 2008 Ford Taurus and the instruction manual says to connect the pink wire to the CAR SPEED SIGNAL INPUT, is that the VSS wire? I have a Ford wire schematic and I can not find the VSS wire. Any help would be appreciated, thanks.
Doug
Posted Dec 16, 2007 · 22:40 UTC#2
Not too sure where you will find this info. The car is very new and no one has really modified one yet. Your best bet is probrably going to be tracing the wire from the VSS sensor on the transmission or maybe you will get lucky and find it in the stock radio harness if you have the speed sensitive volume control feature. One of my cars was like this, and I know a lot of new Fords have this feature.
Maybe do some searching on a Ford 500 message board since the car has a lot in common with the 500. I'm a member of a Taurus message board and have not seen any of the information you are seeking yet, not too many newer Taurus owners there.
Good luck, the Z2 will look great in that car!
Posted Dec 17, 2007 · 12:48 UTC#3
Thanks for the info, I contacted the dealership and there is a wire that is located at the radio wire harness in all the new models and hooked it up and it works great, know i have to figure out why the screen does not dim done, other than that it works great. Thanks.
Posted Dec 17, 2007 · 15:22 UTC#4
Nice!
Do you have a multimeter? There should be a wire in your radio harness that goes +12V when the lights are turned on. In an aftermarket harness it's the orange wire.
Posted Mar 09, 2008 · 08:32 UTC#5
What color wire is your VSS in your Ford stereo harness? I need to find one for my 2007 Ford Fusion. It may be the same!
Posted Mar 09, 2008 · 13:37 UTC#6
your dealership doesnt know what they are talking about. the new ford lines do not have the vss in the radio harness anymore. they dont have one anywhere. your system is working fine because the pioneer units will work without it. if you go into your connection status screen,you will see that the speed pulse numbers do not change when you drive. that means the vss is not hooked up.
