D1 questions
By BIGDUB · Dec 16, 2007in General💬 5 posts👁️ 809 views
Posted Dec 16, 2007 · 05:16 UTC#1
Hi I just installed a D1. Does the bypass for the D3 parking brake work for the D1? Also, I bought the D1 used with no map, so i got one on ebay, and it says to insert the right disc. Which disc do i need to buy, or is there a place where i can download the file and burn it to a disc? Also, does anyone know where i can find a radio sleeve for it? When it was shipped the cage got crushed....
thanks a lot
Jeff
Posted Dec 18, 2007 · 00:22 UTC#2
thanks a lot
Jeff
Can't tell you much about your other questions but if you need the correct discs that came with the AVIC-D1, I have the CNDV-50MTP set (equivalent upgrade set to AVIC-D1). Let me know if you want the set (or even just either the East or West disc).
Posted Dec 18, 2007 · 03:00 UTC#3
1. The bypass is the same as the D3
2. Demand the seller give you a properly working disc and make sure you ordered a disc that is compatible with the D1.
3. Call Pioneer to order the cage. Should be less than $30.
Posted Dec 18, 2007 · 03:32 UTC#4
Empty hole for the bypass is in the main power harness on D1/2, not in the little white one like on the D3. Same otherwise
Posted Dec 19, 2007 · 03:05 UTC#5
Ok, cool. Thanks guys. I have actually bought a set of CNDV-60MT discs from a guy on here as well as a cage, and then i ordered a trim piece from pioneer direct. I did the bypass the other day, and it worked, so i went with it. So all in all, i think i am good now. It sounds amazing!
Jeff
