HELP with the speed sensor
By johnha211 · Dec 18, 2007in Problems/Troubleshooting💬 3 posts👁️ 619 views
Posted Dec 18, 2007 · 22:52 UTC#1
Well... i have D3 installed in my car.. and i paid $80 more to connect the speed sensor and it still not working.. BTW i have 2007 altima 2.5 ls.. the navigation is not acurate at all...what should i do should i take it back?? i need a good advise.
Posted Dec 18, 2007 · 23:43 UTC#2
Have you tried resetting everything under the learning status? Also, you can try resetting the whole system by pressing the button on the top left corner of the D3 with a pin.
Posted Dec 19, 2007 · 15:26 UTC#3
i would try a 3d calibration also, in the manual.
calibrates the internal gyro.
how closely does the speed match if you hit map view then map & select vehicle dynamics?
