Speed pulse wires loc.2003 Infiniti qx4/Nissan Pathfinder LE
By berniec ยท Jul 23, 2006in Vehicle Specific Wiring๐Ÿ’ฌ 2 posts๐Ÿ‘๏ธ 1,858 views
Posted Jul 23, 2006 ยท 01:52 UTC#1
anybody have this truck and know the easiest spot to tap into the speed pulse wire? The spec sheet I have says its a white/blue wire behind the instrument panel, but getting behind there is next to impossible without taking nearly all the dash apart. I'm hopeing somebody found a slightly more accessable spot where that wire passes through.
thanks
Bernie!
Posted Jul 24, 2006 ยท 04:17 UTC#2
UPDATE
two phillips screws hold the bezel around the guage pod on and then 4 more philips screws hold the guage pod itself on. Once you pull them out its the white/blue wire.
works great :D
