V Blue, good data,
that is my intention: better sound, with less parts (no amps & cross over & power blocks & caps & RCAs)
HiFi, it's pretty common (at least it was ~10 years ago when i was into stereos) to run multiple speakers in Tri-mode,
you ran one huge amp with one set of full range RCA outputs.
you ran a speaker off each channel, with a passive high cross over,
and that was your stereo,
and one (or two - like you said about the ohms) subwoofers in Tri mode, with passive low pass crossovers,
and you had a complete system with minimal wiring and components.
i just dont' know how "rugged" the D3's internal amp is.
as you have posted in other threads, it's a "price leader" type unit, that does a lot of "good" things,
but i was wondering if the internal amp was "good" or "excellent."
i think i will take VBlue's advice, and just run some nice components (better clarity) and let it go at that.
I've done the whole "take the dash out, cut holes in it, dissassemble the tweeters, and reassemble them around the dash" stuff.
lots of work. sounded good, great imaging, but LOTS of work.
