OK, i guess I'm stupid.........?!?!
By Mo-D · Dec 19, 2007in Hacks/Mods💬 5 posts👁️ 1,177 views
Posted Dec 19, 2007 · 23:34 UTC#1
I bought a new car for my Z1 (LOL) and I figured while I was installing it I would wire up the 2-wire bypass. I wired it through a SPDT switch so I could have it in bypass mode, or normal parking brake mode. Anyway, I read that you are supposed to insert the update CD and press "MAP" to do the update. But, it's not working. Am I supposed to put the CD in and press MAP right away, or wait until after it checks the disc and says "CD ROM inserted"? I've tried it both ways, so I guess I burned the file wrong??? I unzipped the file, and then using ISO Recorder I did "Copy image to CD" on the AvicBluetoothFix.iso file. Any ideas???
Posted Dec 19, 2007 · 23:47 UTC#2
Just double click the iso file. It should automatically open a burning program for you
Posted Dec 21, 2007 · 06:05 UTC#3
It does, but it opens the same program, the Iso Recorder. If I were to view the CD in windows explorer, what should it look like? in the root I have some folders and some files. I don't have Nero or anything else on this computer.
Posted Dec 21, 2007 · 07:32 UTC#4
I use Active ISO burner. It worked the first time
Posted Dec 23, 2007 · 21:03 UTC#5
Thanks for the tip. I downloaded that program and it worked. I guess the ISO recorder program burned in a different format or something. The file structure on the CD looked the same. Oh well, it works now.
