Please help! Avic Z2 and Evo, No Sound
By m4tt viii · Dec 20, 2007in Problems/Troubleshooting💬 4 posts👁️ 827 views
Posted Dec 20, 2007 · 00:33 UTC#1
I got the orbital double din, installed everything and have put the harness into the Avic Z2 and I get no sound out of my speakers... There are two things that were plugged into the back of the original infinity system... One of which is a single black audio cable that I've plugged into the the back of the Avic, the other one there isn't a spot for, but I was told it wasn't necessary. What am I doing wrong or how can I fix this??? Thanks Matt
PS (I tried my stock headunit and when (harness, single black cable and other plug) are in it works)
Posted Dec 20, 2007 · 02:29 UTC#2
bump
Posted Dec 20, 2007 · 21:59 UTC#3
Do you have the SSL option package? I.e. the subwoofer and amplified speaker system.
Posted Dec 27, 2007 · 14:51 UTC#4
You will rpobrably have to do a little searching because one of those wires is to turn on your factory amp. It's more than likely going to need a switched 12v source and then you will have sound.
If you are giving your amp speaker level inputs it may sound like sh*t and the volume may be very sensitive. If this is the case wire in the front and rear outs instead.
