steering wheel control question
By spoogy · Dec 22, 2007in Hacks/Mods💬 14 posts👁️ 3,348 views
Posted Dec 22, 2007 · 09:13 UTC#1
Hey guys, I'm a fellow "Newbie" D3 owner and tomorrow I am going to attempt to install it in my 02 explorer. I want to retain my steering wheel controls but when I was buying the unit I was told that I would not need an adapter for the controls to work and that it would be a simply "plug and operate" situation. Is this true or would I need this PAC-SWI-PS that I've seen everyone using??
Secondly if anyone has any info as to where the VSS wire for my truck is located if it has any??
Much thanks!! :?
Posted Dec 22, 2007 · 09:30 UTC#2
Yeah, you'll need the adapter for the steering wheel controls to work.
Posted Dec 27, 2007 · 17:12 UTC#3
I have the same question about a different SUV. I just got my wife an '03 Lincoln Aviator and it too has steering controls. Is the adapter previously discussed the same adapter I would need in order to maintain the steering wheel controls?
Posted Dec 28, 2007 · 12:27 UTC#4
yes, you both need the pac swi-ps. and the vss is grey/black in the radio harness on both vehicles
Posted Dec 31, 2007 · 08:40 UTC#5
yo thanks alot man
Posted Dec 31, 2007 · 08:41 UTC#6
yo thanks alot man
Posted Feb 23, 2008 · 05:44 UTC#7
How about on a 2006 Impala...any idea what wire I'd need to tap into?
Posted Feb 23, 2008 · 12:37 UTC#8
Speed Sense brown ABS module, pin 21
The ABS module is in the driver side rear corner of the engine compartment. On the V8 models, the VSS wire is also orange at the ECM, gray plug, pin 45. The ECM (Engine Control Module) is behind the driver side headlight, in the air cleaner assembly
Posted Feb 24, 2008 · 00:53 UTC#9
Is the appropriate wire in the Pioneer unit going to be long enough to reach either of those? I don't have the HU from crutch yet, so I;m just trying to prepare myself for the install.
Posted Feb 24, 2008 · 02:27 UTC#10
it might. its pretty long. if not, just extend it
Posted Feb 26, 2008 · 17:58 UTC#11
Thanks for the replies. Got the package today and need to start hunting these locations down. I'm familiar with the ECM, as I had to move it around when I installed the K&N INtake. I'll just have to look for the ABS module. Again, thanks for your help.
Posted Feb 27, 2008 · 17:58 UTC#12
Just wanted to update my scenario. The inclusion of the GMOS chime/onstar module eliminated the need to find these wires. It does it for you. A big thumbsup to Axxess for this product.
Posted Mar 16, 2008 · 06:08 UTC#13
hello I have a 05 F-150 and I to would like to use my steering wheel controls will this PAC-SW1-PS work for my pickup too and where can I get one
thank you
Posted Mar 16, 2008 · 06:31 UTC#14
thank you
Yep
crutchfield
best buy
circuit city
