Tundrs Tach wire location
By medkat · Dec 22, 2007in Vehicle Specific Wiring💬 2 posts👁️ 1,320 views
Posted Dec 22, 2007 · 14:07 UTC#1
Help! I am trying to find a tachometer wire on a 2005 toyota tundra double cab. The information I have says it is a black wire in the ECM which is behind the glove box. I can not find it. Anyone got better info?
Posted Apr 16, 2008 · 15:28 UTC#2
When you say tachometer, do you mean the vehicle speed sense wire (vss), If so here's the vss info:
Speed Sense = GREEN/ORANGE (AC) 35 PIN CONNECTOR AT THE ECM PIN 17 (8 CYL)
ON A 6 CYL THIS WIRE CAN BE FOUND IN A 22 PIN CONNECTOR AT THE ECM PIN 6
Just in case you do mean tach wire:
Tachometer = (AC) AT IGNITION COIL, CAN ALSO BE FOUND AS A BLUE/WHITE 31 PIN CONNECTOR AT THE ECM PIN 5 (8 CYL.) BLACK/BLUE AT THE COIL ON A 6 CYL
