tejashd Posted December 26, 2007 Report Share Posted December 26, 2007 I've done some searching on the site and found some installs in 2005 superduty trucks.... I've got a 2002 excursion and want to install a D2 that I have laying around, just wondering if anyone has done the install? I am trying to make sure that I get the right dash kit, and the one I see on Crutchfied does not look right to me. I posted becuase I think there are some differences between the 02 and 05 dash.... Thanks! Quote Link to post Share on other sites
cntrylvr79 Posted December 27, 2007 Report Share Posted December 27, 2007 Can you post a pic of the dash of the truck. Be a bit easier to help you get the right stuff. Quote Link to post Share on other sites
riggz Posted December 28, 2007 Report Share Posted December 28, 2007 I have an 04 Super Duty and my g/f's father has an 01 Excursion. We both have the D3 installed. The pre-05's are not a true double DIN so the install is not just an easy swap. His was installed at Circuit City and it sits kind of behind the dash trim. I shaved the top and bottom of the opening down with a file and used Best Kits BKFMK552 to mount it. And yes it is an 04 with the 05-07 lower dash panel installed. I upgraded the lower dash so I could have the upfitters with a factory look. Quote Link to post Share on other sites
tejashd Posted December 29, 2007 Author Report Share Posted December 29, 2007 I have an 04 Super Duty and my g/f's father has an 01 Excursion. We both have the D3 installed. The pre-05's are not a true double DIN so the install is not just an easy swap. His was installed at Circuit City and it sits kind of behind the dash trim. I shaved the top and bottom of the opening down with a file and used Best Kits BKFMK552 to mount it. And yes it is an 04 with the 05-07 lower dash panel installed. I upgraded the lower dash so I could have the upfitters with a factory look. That's what my dash looks like. so, with that kit, everything bolted right in and the only mod you had to do was file the opening on the outer dash cover? Thanks for all the help! Quote Link to post Share on other sites
