mrgoodbar67 Posted February 1, 2008 Report Share Posted February 1, 2008 i have an avic d3 and just bought a btb200 and noticed it has no switched power (red) wire on its power harness. Is that normal, is that how it comes? anyway, so i was trying to install the btb200 by piggy backing the ipbus to my xm navtraffic unit and then spliced into the xm box's constant power wire (yellow) and ground wire (black). but.......i noticed that nothing happend. the xm was bit getting power and the icon did not light up like it did before attempting the piggy back/ splicing install and neither did the bluetooth icon get power nor bluetooth button light up. so then i decided to scrap the install until the weekend and attempted to reattach the yellow xm wire and black ground wire to power back on my xm......but nothing happened, no pwer. whats up? if i did it wrong.....please tell me how. Quote Link to post Share on other sites
cntrylvr79 Posted February 1, 2008 Report Share Posted February 1, 2008 probably blew the fuse on the constant wire of the xm tuner. And it is normal for there to be no switched line in the btb200's power harness. Quote Link to post Share on other sites
mrgoodbar67 Posted February 1, 2008 Author Report Share Posted February 1, 2008 oh and i forgot that the xm constant had no fuse............so that probably wasnt it. anything else. how should i install the btb? should i proceed or try some other way Quote Link to post Share on other sites
cntrylvr79 Posted February 1, 2008 Report Share Posted February 1, 2008 Do you have power on that wire? if not, then there's a fuse blown somewhere. Also make sure you have ground too. No other way to hook the stuff up. Tie constant to constant, ground to ground. And plug the ipbus cable in. Not much to it. Quote Link to post Share on other sites
mrgoodbar67 Posted February 1, 2008 Author Report Share Posted February 1, 2008 "not much to it", thats what i think too. the xm has constant to it coming from the avic d3's constant so it should have power. i dont know whats up. this sat i will remove the glove box to be able and really get into the install and wiring.....you never now maybe the little pulling and tugging i did caused the xms constant wire to seperate from the d3's constant. eh, well see. thanks fellas. ill advise on results. Quote Link to post Share on other sites
mrgoodbar67 Posted February 3, 2008 Author Report Share Posted February 3, 2008 ok fellas install is done. it turned out that the ground was not grounded which was causing my problem. all is good. thanks Quote Link to post Share on other sites
