junior Posted February 10, 2008 Report Share Posted February 10, 2008 i need help locating the vss and the reverse so i can tap into them. i don't know where to plug the pink and the violet with white. i have and 02 mustang with the mach 460 in it Quote Link to post Share on other sites
MisFit Posted February 10, 2008 Report Share Posted February 10, 2008 Reverse Light black/pink + 26 pin plug, pin 20 at GEM The GEM (Generic Electronic Module) is located above the driver kick panel Speed Sense white/orange pin 68 at PCM The PCM (Powertrain Control Module) is located behind the passenger kick panel Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 do i have to disconnect the whole computer then pull it out to find that cable the mach 460 has a white orange cable in one of the plugs that was for my factory stereo but no longer using it with the avic d3 can that one be it? Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 my 02 factory radio did have the feature when the car went faster the volume went up so can it be that white orange cable in the original wiring harness? Quote Link to post Share on other sites
MisFit Posted February 10, 2008 Report Share Posted February 10, 2008 no, you dont disconnect it. you can test that wire in the radio harness to see if its the same wire Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 how do i do that Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 what about the reverse one is it under the steering wheel column Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 can i hope it is that white and orange cable and just tap into it or is that to dangerous. Quote Link to post Share on other sites
MisFit Posted February 10, 2008 Report Share Posted February 10, 2008 its actually one of the few wires that arent dangerous because the avic only reads that wire. it doesnt output anything to it. so if its the wrong one it just doest work. no harm done. but your still better off testing it with a voltmeter or a computer safe test light anyway Quote Link to post Share on other sites
installermarc Posted February 10, 2008 Report Share Posted February 10, 2008 It is possible, but not likely. If it has three plugs (besides the antenna) then it may. It would be a more squarish plug between the power/speaker harness and the subwoofer harness. Â Also, the dash may look like a tight fit top to bottom, but the D3 will fit right in. It looks great in the dash of my 2001 Mustang Bullitt, so I am probably biased. Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 so the plug that im not using on my factory radio has a white/orange and 2Xblue/red cables that are not hooking up to my avic. is the reverse really necessary if im not using a reverse camera Quote Link to post Share on other sites
MisFit Posted February 10, 2008 Report Share Posted February 10, 2008 no, not at all Quote Link to post Share on other sites
junior Posted February 10, 2008 Author Report Share Posted February 10, 2008 i dont have a meter to test that cable i think im going to take my chances Quote Link to post Share on other sites
