matrixneo515 Posted April 4, 2008 Report Share Posted April 4, 2008 I have a 2004 Jeep Grand Cherokee with the AVIC-N4 installed everything is flawless although I did not hook up the reverse wire or the speed sensor because I did not know where to look to find them... After much searching on the net I am still not successful in finding the exact location of these wires... Can anyone help me??? Thank you so much. Quote Link to post Share on other sites
Fracken21 Posted April 16, 2008 Report Share Posted April 16, 2008 The reverse should be pretty easy to find, the vss though may be a little harder. my source says: reverse = violet/black (+) in harness in passenger kickpanel Speed Sense(VSS)= White/orange (AC) At the PCM located on the right side of the engine compartment Another source says VSS= VSS Wire: AUTOMATIC TRANS. 4 CONNECTOR ECM- RIGHT GREEN CONNECTOR POSITON 32, MANUAL TRANS. 3 CONNECTOR ECM POSITION 13 VSS Wire Color: AUTOMATIC LT. GREEN/WHITE or GREEN/BROWN or MANUAL WHITE/ORANGE Quote Link to post Share on other sites
