crhatch02 Posted August 16, 2008 Report Share Posted August 16, 2008 alright I have the unit hooked up to my avic d3...but when I get my phone hooked up to it(htc mogul) it doesnt give me any kind of options..It will notice my phone and i will be able to accept calls...but there is no function menu to choose...it also wont let me make calls from my d3 just accept. The only button I can push on the screen is "Voice"...........but the function menu will work with my bluetooth audio...I get a connection open dissconect and device info to choose from with the BT Audio Menu........ And if I make a call with my phone it will pick it up in the d3 and I will be able to use it then. I NEED HELP Quote Link to post Share on other sites
JLeach12 Posted August 16, 2008 Report Share Posted August 16, 2008 after u pair the unit register it and you will get all the features Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 16, 2008 Report Share Posted August 16, 2008 after u pair the unit register it and you will get all the features he said the phone can accept calls so it is paired and connected.. do you have the unit bypassed?? Quote Link to post Share on other sites
crhatch02 Posted August 16, 2008 Author Report Share Posted August 16, 2008 nope...its not bypassed Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 16, 2008 Report Share Posted August 16, 2008 theres your problem. phone options like that can only be done if the parking brake is up (if you tapped the wire to it) or if you bypass it. its a safety feature pioneer added Quote Link to post Share on other sites
crhatch02 Posted August 16, 2008 Author Report Share Posted August 16, 2008 well when Im tryin all this out, my car is parked with the ebrake up.. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 16, 2008 Report Share Posted August 16, 2008 well did you tap the parking brake wire from the unit to the OEM parking brake wire? Quote Link to post Share on other sites
crhatch02 Posted August 16, 2008 Author Report Share Posted August 16, 2008 nope...I havent done anything to the harness...except hook it up my my existing harness......Im assuming I havent read up on it enough Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 16, 2008 Report Share Posted August 16, 2008 no, you just didnt hook it up to the parking brake or bypass it..how do you expect it to know the parking brake is up if the unit's not connected to it? anyways, since you have to take the unit out to do either of the 2, id just bypass it...you'll be glad you did when you have to make a phone call while driving lol. to do the bypass: take the mute wire (its the black and yellow wire on the connectors with the RCA's) and pull the wire out of its slot, and relocate it to the empty slot directly below it. then you ground that wire and the parking brake wire (light green wire on the main connector) and it will be bypassed. then you can also watch movies and do nav functions while driving as well. PS: just be careful when pulling it out, its locked in, so use a small sharp object to release the lock (i use a pocket knife) Quote Link to post Share on other sites
crhatch02 Posted August 16, 2008 Author Report Share Posted August 16, 2008 that might be my problem....I dont have the harness for all the rca's...i just have the main harness Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 16, 2008 Report Share Posted August 16, 2008 then your 2 options are to either get that rca harness or just connect the parking brake wire to your parking brake. personallly i think getting the rca harness is the better option, besides the ability to bypass, if you ever decide to later sell it, your chances of someone buying it without all the connectors is not very likely. Quote Link to post Share on other sites
crhatch02 Posted August 16, 2008 Author Report Share Posted August 16, 2008 hmmmmm..ok.Thanks for all the help Quote Link to post Share on other sites
EclipseAVH Posted September 8, 2013 Report Share Posted September 8, 2013 Sorry for bringing up this old thread but I have a question with the bypass. I already have bypass my stereo to watch dvd on the go but now I just got the BTB200... does this has to be bypass as well? If so, when I got my btb200 unit from a seller it has 3 wires (red,black and yellow) and the stock pioneer wire is yellow and black. How can I do this? I circled with a cyan color over the 3 wires from the btb200 on the right and the two circled on the left is from the harness to the avhp4200. Also I'd like to add there is no fuse connected to the yellow wire (the stock has a built in fuse holder) is it ok to tap it in without the fuse? Thanks! Quote Link to post Share on other sites
VBLUE42 Posted September 8, 2013 Report Share Posted September 8, 2013 There is also a red wire on the head unit harness. Quote Link to post Share on other sites
