ShaunArmada Posted August 21, 2008 Report Share Posted August 21, 2008 i just purchased the CD-BTB200 is hard to installed my radio in my armada.Also does it work with the att blackjack and does it bluetooth music to the radio Quote Link to post Share on other sites
kdoll36 Posted August 21, 2008 Report Share Posted August 21, 2008 i just purchased the CD-BTB200 is hard to installed my radio in my armada.Also does it work with the att blackjack and does it bluetooth music to the radio No, its easy to install. Plug it in the back, run the yellow wire to the yellow on your D3 harness, run the black to the ground wire on the harness or any other ground point, and then place the mic where you want it. Yes it works with the Blackjack, or at least my d3 and blackjack worked flawlessly, and again yes it supports stereo bluetooth so long as your phone does, and if you have the blackjack your fine. Quote Link to post Share on other sites
