lalnhl99 Posted September 3, 2008 Report Share Posted September 3, 2008 i switched from the Ipod to the Sirius today and the Sirius is stuck on channel 24 but with no sound. I try to change the channel but it wont work. Then when I change back to the Ipod, its somehow muted. Ill put the volume all the way up and you can barely hear it. But if I turn the truck off then on again, the volume is restored for the ipod, but the sirius still wont work. How do I fix this?? Quote Link to post Share on other sites
etedford Posted March 19, 2009 Report Share Posted March 19, 2009 Hello, I am currently having the same problem. My Sirius is stuck on channel 100. I am going to remove the NAV system and mess around with some connections and see if that fixes the problem. The fix might be powering the unit up with the Sirius disconnected and then reconnecting and powering the system back up. I will let you know what I find out. Talk about a pain in the arse, not impressed. Quote Link to post Share on other sites
PhilR Posted September 20, 2010 Report Share Posted September 20, 2010 I'm having the same problem, has anyone come up with a good fix? The unit will sometimes freeze on whatever the last Sirius channel was, with no sound and no ability to change channels. The screen keypad and bottom up/down switches beep when used, but don't change the channel. It usually corrects itself after a day or so, but the intervals are getting longer. All other functions work well (tuner, cd, etc.) Thanks! Quote Link to post Share on other sites
harley909 Posted September 21, 2010 Report Share Posted September 21, 2010 Try unplugging the Sirius module (both power and interface cable) and then plug it back in. I had the same problem once at that worked for me. Quote Link to post Share on other sites
PhilR Posted October 2, 2010 Report Share Posted October 2, 2010 Try unplugging the Sirius module (both power and interface cable) and then plug it back in. I had the same problem once at that worked for me. This worked, my Sirus is back to normal now. Thanks for the tip! Quote Link to post Share on other sites
