brunp Posted September 30, 2008 Report Share Posted September 30, 2008 Well....just noticed that my illumination wire is not hooked up to anything at the moment. Currently figure out where I should hook it up too.... Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted September 30, 2008 Report Share Posted September 30, 2008 The illumination wire from your car. Quote Link to post Share on other sites
brunp Posted September 30, 2008 Author Report Share Posted September 30, 2008 The illumination wire from your car. nope...from the Pioneer D3 unit.....not crimped to anything. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted October 1, 2008 Report Share Posted October 1, 2008 I know that. Connect the Illumination wire from your AVIC to the illumination wire in your CAR. Quote Link to post Share on other sites
brunp Posted October 1, 2008 Author Report Share Posted October 1, 2008 doesn't really work that way because I have Daytime Running Lights and the light switch on my Saab does squat. The low-beam lights are on all the time. Paul Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted October 1, 2008 Report Share Posted October 1, 2008 Ohhhhh, well you didn't say you had a Saab The wire can be tapped into any + wire that turns on at night time, ir a cigarette lighter bulb, and running lights, etc. Quote Link to post Share on other sites
brunp Posted October 13, 2008 Author Report Share Posted October 13, 2008 well....I had some time today (Thanksgiving in Canada) of all days to get back in there and play around. I had some extra wire left from the bypass after I cut the parking brake wire short to accommodate the bypass. So, to ensure I can always reverse this install, and since I didn't have a crimp tool, I cut the crimp connector and manually connected the wires and taped it with electrical tape. I then fed the wire down to the power led that lights up the cig. light. This light turns off when I switch the headlights off and turns on when I switch the lights on, so a perfect source for the day/night mode wire. I looked at the connector and noticed there was enough room to feed the wire into the connector without crimping or wire-tapping. I tested the signal and noticed it was working, so I them electrically tapped the wires together so when putting the dash all back together, the wire wouldn't get loose. After putting the dash back together, I tested it again and now the day/night mode works beautifully. Now, I just need to remember now to actually turn the headlight knob because I never used it before. Paul Quote Link to post Share on other sites
jlong1987 Posted October 13, 2008 Report Share Posted October 13, 2008 Daytime Running Lights are different the Automatic Headlights. Daytime Running Lights by defenition are: A daytime running lamp (DRL, also daylight running lamp or daytime running light) is a lighting device on the front of a roadgoing motor vehicle, installed in pairs, automatically switched on when the vehicle is moving forward, and intended to increase the conspicuity of the vehicle during daylight conditions. Where as Automatic Headlights: A system deployed in a a vehicle that will sense the current light conditions and turn on lights in the vehicle. Lights that are often included would be those on the front and rear of the vehicle along with interior dash lights. As you can see if your lights (all of them) come on automatically then you would have automatic headlights. If your headlights came on when you turn on the car but it does not turn on your interior lights or your tail lights you would have Daytime Running Lights. Even in cars that have automatic headlights you can override the settings and turn on the switch which would enable all of your lights. Most GM cars for the last 5-10 years have had some form of automatic lights. Quote Link to post Share on other sites
brunp Posted October 13, 2008 Author Report Share Posted October 13, 2008 whatever the case may be in my car, I now am able to switch between day and night mode in my car. Paul Quote Link to post Share on other sites
