OJC12 Posted October 23, 2008 Report Share Posted October 23, 2008 I am experiencing with software problem on my AVIC-F900BT & was wondering if anyone would like to help me out with it. I am willing to pay as long as the problem gets fixed for good!! Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted October 23, 2008 Report Share Posted October 23, 2008 Well what problems are you experiencing? Quote Link to post Share on other sites
OJC12 Posted October 24, 2008 Author Report Share Posted October 24, 2008 well, when i installed the radio & tried to bypass it, it worked fine for a day & then it started to reset itself over & over while I was driving. When I am at a set place, it works fine. I hooked everything back up the way is supposed to do with no wire bypass & it still didn't work. So what I did was, disconnect the Navi antenna & it works great except no navigation. How could I fix this & is there a way the software could be bypass??? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted October 24, 2008 Report Share Posted October 24, 2008 did you try a hard reset? hold eject and press reset it back to day 1. The bypass, if done correctly, would not have done that. Yes there is a software bypass. http://www.avic411.com/forum/viewtopic.php?t=17715 Quote Link to post Share on other sites
OJC12 Posted October 24, 2008 Author Report Share Posted October 24, 2008 I just tried the reset & that didn't work. Now, I want to do the software thing but I really don't understand it. How do I put my deck in test mode? How do I change that file step by step? Quote Link to post Share on other sites
rock99rock Posted October 24, 2008 Report Share Posted October 24, 2008 All of your questions regarding all hacks, can be found in the sticky at the top of the mods forum. http://avic411.com/forum/viewtopic.php?t=18327 Good luck Quote Link to post Share on other sites
OJC12 Posted October 26, 2008 Author Report Share Posted October 26, 2008 Thanks you guys!! I finally figured out was I am doing & hopefully I will fix my problem. Quote Link to post Share on other sites
OJC12 Posted October 26, 2008 Author Report Share Posted October 26, 2008 Still doesn't work. I did the software bypass & it still resets itself after 10 seconds of me driving the car. Any ideas??? Quote Link to post Share on other sites
rderango Posted October 27, 2008 Report Share Posted October 27, 2008 Is your harness connections loose? You say its fine when your not moving, so maybe when you do start driving a ground wire or power wire looses its connection. Quote Link to post Share on other sites
OJC12 Posted October 28, 2008 Author Report Share Posted October 28, 2008 No. I double check the wiring & its fine. It works great when I unhook the GPS antenna so its something with the software. Quote Link to post Share on other sites
