jar703 Posted September 20, 2006 Report Share Posted September 20, 2006 Hey, can somebody help me out how to install my pioneer ipod adapter cd-ib100 to avic n1.. I connected the ip bus cable and everything but I still can't figure out how to work it. I don't know if the adapter itself is broken because I bought it used. I tried following the instruction in the manual but I don't see the function selection on the screen. Help please! Thanx Quote Link to post Share on other sites
cntrylvr79 Posted September 20, 2006 Report Share Posted September 20, 2006 Make sure the ip-bus cable is plugged into the output of the ipod interface. Also make sure the yellow wire is hooked up to a constant power source and the black wire is hooked up to a solid ground. Now plug the ipod cable in the dock connector. When your looking for the source list, the ipod will be ext-1. The n1 doesn't list the ipod as ipod since the interface was released after the n1 was built. Quote Link to post Share on other sites
jar703 Posted September 20, 2006 Author Report Share Posted September 20, 2006 So I need that yellow and black harness... It didn't come with it when I bought it. I thought I only had to plug in the ip-bus cable... You know where I can get those yellow and black wires? Thank you Quote Link to post Share on other sites
diskzero Posted September 20, 2006 Report Share Posted September 20, 2006 You could contact Pioneer directly. I don't see that specific part on a parts list. If you are comfortable, you could try and fabricate a connector and run a ground and fusable power lead. It sounds like a lot of hard work though. Quote Link to post Share on other sites
