jbg Posted January 6, 2009 Report Share Posted January 6, 2009 Connects2 is a low cost option that works the best. Their adapter was barely released last year for my car, 06 A3. It should cost around 70-80 shipped to U.S. and takes around 5-10 days depending how close you are to the UK. Everything is plug and play. The only thing you need additional is a wiring harness that you plug into the Connects2 unit and solder on to the Pioneer HU wiring harness. I've used the Metra 70-1784, since it has all the wires I need. Just solder on the Pioneer harness, as if you're doing a regular install, and plug the connector to the Connects2 connector. Their is a Main connector on the Connects2 as well that is to be plugged in the OEM harness connector. Depending on what kind of connector you have for OEM (FAKRA/ISO in Audi models), you would choose the appropriate one. It's so simple. Not to mention the connects2 is already wired for OEM VSS, Reverse Brake, and Illumination. ALL PLUG N PLAY, even the ground is PLUG n PLAY!!!!! not unusual, but still. Quote Link to post Share on other sites
uberGTI Posted January 29, 2009 Report Share Posted January 29, 2009 Here is a link to the installation instructions for the Connects 2 kit. It looks super easy. I'd confirm, but I'm still waiting for mine in the mail. http://www.connects2.com/Instructions/stalk.pdf[/url] Quote Link to post Share on other sites
uberGTI Posted February 8, 2009 Report Share Posted February 8, 2009 I finished the install and it was super easy. You just need to connect the wires from the connect2 to the appropriate wires on your stereo's harness and plug everything in. Running the wire for the F90BT microphone was much more of a pain by comparison. The whole install took less than 45 minutes and that included cleaning up some of the shoddy work from the stereo shop that installed my D3. I'm glad I did it myself this time. Quote Link to post Share on other sites
brianteel Posted February 9, 2009 Report Share Posted February 9, 2009 awesome i am moving my f90bt from my truck to my income Tiguan. The connect 2 sounds like a awesome option and the best thing is that my sisters fiance is from UK and he is coming in 3 weeks. no shipping there. I dont remember what the bottons are on the steering wheel what is on the left and the right. also did you need an antenna adapter for the install. if so where did you get it from. Quote Link to post Share on other sites
brianteel Posted February 9, 2009 Report Share Posted February 9, 2009 so saw a couple people interested in these. I am sure one of us (like my self) could order a bunch have them shipped over then resend them. Quote Link to post Share on other sites
uberGTI Posted February 9, 2009 Report Share Posted February 9, 2009 awesome i am moving my f90bt from my truck to my income Tiguan. The connect 2 sounds like a awesome option and the best thing is that my sisters fiance is from UK and he is coming in 3 weeks. no shipping there. I dont remember what the bottons are on the steering wheel what is on the left and the right. also did you need an antenna adapter for the install. if so where did you get it from. You will need a powered antenna adapter for any VW install. I picked up a Metra from a local stereo shop. You should be able to find one at enfig.com as well. How do you like your Tiguan? I'm thinking about one when I finally am ready to part with my GTI. I'm holding out for the DSG transmission. Its either that or a MkVI GTI R20. If VW finally brought over a TDI Tiguan I'd really be sold. Quote Link to post Share on other sites
brianteel Posted February 9, 2009 Report Share Posted February 9, 2009 it has not come in yet prolly end of next week. from the test drive i love it. solid like every VW but 4 motion and can carry alot. Quote Link to post Share on other sites
letterman52 Posted February 10, 2009 Report Share Posted February 10, 2009 I am installing this in my rabbit and am about to wire the Pac CR2 VW harness. Since I do not have steering wheel controls that is all I needed. My question is how does the harness wire up? I looked at the PDF on there site and got myself rather confused. Any 08 VW Rabbit owners care to help me out on that. I am sure the OP's wiring for that module is that same so if he wants to chime in that would be awesome. Quote Link to post Share on other sites
brianteel Posted February 10, 2009 Report Share Posted February 10, 2009 send me the PDF i should be able to explain it. from what i have seen you have to just connect the wires and go. Quote Link to post Share on other sites
brianteel Posted February 10, 2009 Report Share Posted February 10, 2009 i am looking it now what is the problem you are having Quote Link to post Share on other sites
letterman52 Posted February 10, 2009 Report Share Posted February 10, 2009 I am just curious what wires from the PAC go to the harness for the radio and which wires off the harness in the bottom left of the pic go?? Quote Link to post Share on other sites
letterman52 Posted February 10, 2009 Report Share Posted February 10, 2009 http://www.pac-audio.com/instructions/c2r-vw.pdf Quote Link to post Share on other sites
letterman52 Posted February 10, 2009 Report Share Posted February 10, 2009 I believe it is pins 7-11 on the 11 pin connector. Quote Link to post Share on other sites
brianteel Posted February 10, 2009 Report Share Posted February 10, 2009 7-11 are can bus wires for the steering wheel control break out Quote Link to post Share on other sites
