cshen Posted January 26, 2009 Report Share Posted January 26, 2009 I was hoping for a little information. I am a novice when it comes to installing sound systems. My car, a 2002 mustang, with the mach 460 sound system, has 4 tweeters, and 4 subs (attached to two amps). I intend to hook the amplified outputs, with high pass filters, to the tweeters, and the non-amplified front/rear outputs to my Amps/Subs. In the manual it says that the high pass filter can be set to front or rear speakers. Is it referring to the amplified or non amplified outputs? Or is it really dependant on whether the output is designated front/rear? Basically, what specific outputs does the high pass filter apply to? Apologies if this is an obvious question, I have searched for awhile and cannot find the info. Any help would be greatly appreciated. Quote Link to post Share on other sites
1loudls Posted January 27, 2009 Report Share Posted January 27, 2009 the HPF controlls both (amp'ed outputs and preouts for the front and rear) the LPF controlls the sub out (pre-amped) metra makes a Mach harness, 70-5519, wire it up and plug it in, just plug the factory subs into the sub output from the deck, then use the HPF for the tweeters and the LPF for the subs Quote Link to post Share on other sites
cshen Posted January 27, 2009 Author Report Share Posted January 27, 2009 Thanks, that was what I needed. I have the harness. I'll split the preamp sub output and send it to the 4 subs(LPF), then use the amplified output for the 4 tweeters(HPF), and I guess I don't need the front and rear preamp outputs. Thanks again, I appreciate it. Quote Link to post Share on other sites
CamelTowing Posted January 27, 2009 Report Share Posted January 27, 2009 When you say 'subs,' do you mean midbass in your doors? Or subwoofers in your trunk? Quote Link to post Share on other sites
cshen Posted January 27, 2009 Author Report Share Posted January 27, 2009 The mach460 system is generally described as having 4 tweeters (2 in front, 2 in back) and 4 subs (2 in front, two in back). I thought they were midranges at first...maybe they are close, but every tech reference I find on them says that they are subs (low freq). No, this system does not have a set of large subwoofers in the trunk though. Reccomended filters from mustang tech boards are HPF 170hz tweeters, and LPF 50hz subs. http://www.flemworld.com/Mach460/Mach.html Quote Link to post Share on other sites
