Mloftis19k Posted February 13, 2009 Report Share Posted February 13, 2009 I just installed the new 700BT. It works very well with only a few issues. Is there any way to lower the beeb volume when makeing a selection? I saw the post on deleting the beeb all together, but I'm not that computer oriented. I also have issues with the bass not sounding right. I had a pioneer single din unit before and the bass was deep and clear. Now I cannot set the 700bt to make it sound remotely close to what it sounded like before. It sounds like someone is muffleing the Bass speakers with their hand on the cone. Any suggestions? Quote Link to post Share on other sites
skicrave Posted February 13, 2009 Report Share Posted February 13, 2009 I just installed the new 700BT. It works very well with only a few issues. Is there any way to lower the beeb volume when makeing a selection? I saw the post on deleting the beeb all together, but I'm not that computer oriented. Easiest way to fix it is to read the manual, it's in there. I also have issues with the bass not sounding right. I had a pioneer single din unit before and the bass was deep and clear. Now I cannot set the 700bt to make it sound remotely close to what it sounded like before. It sounds like someone is muffleing the Bass speakers with their hand on the cone. Any suggestions? Check the polarity of your speakers, especially if you did the install yourself. If one or two are reversed it can really wreak havoc on bass response. Quote Link to post Share on other sites
Mloftis19k Posted February 13, 2009 Author Report Share Posted February 13, 2009 I saw that the manual was 192 some odd pages. I was reluctant to print it out, but I did see the settings to change thye beep. Also fixed the subs by switching to full range instead of sub woofer. Teaches me to be more resourceful...l Quote Link to post Share on other sites
skicrave Posted February 13, 2009 Report Share Posted February 13, 2009 Glad you got it resolved. FYI, if you view the PDF version of the manual you can do a full text search to find what you're looking for and just read that section without having to print anything out. Quote Link to post Share on other sites
