BBBold Posted March 11, 2009 Report Share Posted March 11, 2009 For any of you who have a Blackberry Bold and can't get the F90BT to recognize voice dialing, I finally (after many trials and tribulations) got my unit to work perfectly.... - Delete all characters from the name and phone numbers ie; +(),/: etc. - Only use alfa letters and numerics - Only use 10 numerals for the phone number with no spaces between ie; XXXYYYZZZZ instead of XXX YYY ZZZZ - Delete all international phone numbers with more than 10 numerals - Delete all contacts from the phonebook which do not have an associated phone number ie; contacts with only an e-mail address but no phone number Once completed in the Bold, delete your connection from the F90BT and also your connection to the F90BT from your Bold. Then re-marry you phone to the F90BT and download the new phone book. You need to be carefull to fully follow the above directions. If you do, it will work like a charm! Just say "Call FirstName LastName" and the unit will respond with all associated phone numbers, asking which one to dial. Quote Link to post Share on other sites
darkzide Posted March 12, 2009 Report Share Posted March 12, 2009 Or you could just edit your PhoneBook.db file and leave all your contacts as is on your phone . Quote Link to post Share on other sites
Maverickster Posted March 12, 2009 Report Share Posted March 12, 2009 Or you could just edit your PhoneBook.db file and leave all your contacts as is on your phone . ...and here's the thread on how to do that: http://www.avic411.com/forum/viewtopic. ... sc&start=0 If you have a lot of contacts, this is a much quicker way of getting from point a to point b. --Mav Quote Link to post Share on other sites
