Z06PSI Posted March 17, 2009 Report Share Posted March 17, 2009 Getting a loud pop when I turn the head unit on. It is powering a stock subwoofer in a 2005 Navigator. Any way to soften the pop? Maybe a resistor inline? Quote Link to post Share on other sites
rareform Posted March 17, 2009 Report Share Posted March 17, 2009 yes add a resistor in line with the amp turn on, ford amp turn on is 5 volts. To avoid the pop, you will need to add a 12 volt to 5 volt regulator in line on the remote lead. This item can be purchased at any Radio Shack, the part number is 276-1770. And yes you can use a resistor but you will need to test for the value it eludes me at the present time. Quote Link to post Share on other sites
1loudls Posted March 17, 2009 Report Share Posted March 17, 2009 just add a 1450 Ohm resistor inline with the remote turn on wire (common with most ford premium sound systems) Quote Link to post Share on other sites
Z06PSI Posted March 18, 2009 Author Report Share Posted March 18, 2009 Thanks guys. Quote Link to post Share on other sites
Z06PSI Posted April 7, 2009 Author Report Share Posted April 7, 2009 I put a 1.5K ohm 1/2 watt resistor in and the pop is significantly less but it is still there. Quote Link to post Share on other sites
1loudls Posted April 7, 2009 Report Share Posted April 7, 2009 i would try a resistor with a little higher value, maybe 2k or 2.5k, im not sure, 1450 is what we have in our shop and havent had any problems Quote Link to post Share on other sites
2screwed Posted April 7, 2009 Report Share Posted April 7, 2009 What do you do if you have the pop when the amp turns off? Same thing? Quote Link to post Share on other sites
1loudls Posted April 7, 2009 Report Share Posted April 7, 2009 yes Quote Link to post Share on other sites
