How to disable "Snap-to-road" feature?
It isn't enabled in the OEM data.zip. My data.zip and IDT's for sure have the setting. I'm sure a few others do as well. The setting is under NaviSettings/Route where you can also select vehicle type. Check out the mods on my FTP
ftp://avic:avic-411@buckeyecollision.us/
Read the readmes and look at the pix in each user's folder. Any of them are far better than the OEM version, so pick the one you like the best. :-)
I have put an all-in-one file on there in my folder(cmh928) aimed at newbies to get you started modding.
You only need to mod if you want the option displayed when vehicle type = car. Otherwise, just set it to pedestrian and the AlignToRoad is displayed (and off by default). See comments in the "iGO sys.txt" thread: you need to mod both common/ui/setting.ui and sys.txt.
