djtex Posted April 6, 2009 Report Share Posted April 6, 2009 Hello! I'm new here, just had my unit installed yesterday and want to turn the dreaded beeps off. Is there any difference between US and UK models with regard to accessing the test mode? I have followed the instructions and put both the testmode and MiTACAP folders in the root of my SD card. Though when the system boots up I just get this error on the screen.... MapDBinfo:0x1000<=> Device :0x0010 AU: 0x0001 EW: 0x0010 RE: 0x0100 UC: 0x1000 Does anyone have any ideas how I can get round this? I have latest firmware (2.0) installed? I have also reformatted the SD card to Fat 32 wih no joy. Many thanks in advance. Quote Link to post Share on other sites
djtex Posted April 6, 2009 Author Report Share Posted April 6, 2009 No response from anyone? Someone must have some idea whether I am wasting my time, even trying to remove the beeps. Many thanks. Quote Link to post Share on other sites
ricmarzola Posted April 7, 2009 Report Share Posted April 7, 2009 I'm having the exact same problem. My unit is a F900Bt european with firmware 2.001. Quote Link to post Share on other sites
cmh928 Posted April 7, 2009 Report Share Posted April 7, 2009 Try this one. Quote Link to post Share on other sites
djtex Posted April 7, 2009 Author Report Share Posted April 7, 2009 So I'm not the only one. Somebody here must know something given the level of knowledge around. Quote Link to post Share on other sites
djtex Posted April 7, 2009 Author Report Share Posted April 7, 2009 Thanks for that cmh928, much appreciated. Will try tonight. Quote Link to post Share on other sites
craw Posted April 7, 2009 Report Share Posted April 7, 2009 I did not work Quote Link to post Share on other sites
GTIMatt Posted April 7, 2009 Report Share Posted April 7, 2009 So I'm not the only one. Somebody here must know something given the level of knowledge around. On your SD card in MiTACAP\APL2\iGo\content\MapDBInfo.txt you need to change Area from UC to EW if you are using a EU model and downloaded the tesmode files for the US model. Quote Link to post Share on other sites
craw Posted April 7, 2009 Report Share Posted April 7, 2009 Yes I did that, but then a window came where the radio copy the files and suddenly it turned into green and you could not do anything!! And on the sd card is also nothing !! Please help Quote Link to post Share on other sites
GTIMatt Posted April 7, 2009 Report Share Posted April 7, 2009 Yes I did that, but then a window came where the radio copy the files and suddenly it turned into green and you could not do anything!! And on the sd card is also nothing !! Please help Once it's turned green you are in testmode and need to close the copy window by clicking on the x at the top right with the stylus. If you are having trouble hitting the x then you need to recalabrate your screen through the AVIC menu before you go into test mode. Quote Link to post Share on other sites
craw Posted April 7, 2009 Report Share Posted April 7, 2009 But the whole display does not do anything when I touch it!!!! The task list also get green and in the left corner is a button with okay but it did not work!!!! Nothing works!!! Quote Link to post Share on other sites
slothy Posted April 7, 2009 Report Share Posted April 7, 2009 use stylus and click the x in the upper right corner Quote Link to post Share on other sites
djtex Posted April 7, 2009 Author Report Share Posted April 7, 2009 Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thank you so much to everyone for replying, the Eu files worked, and I have now got rid of my beeps. You have saved my Wife and I's sanity! Many, many thanks! :):):):) Quote Link to post Share on other sites
craw Posted April 7, 2009 Report Share Posted April 7, 2009 Thx works now Shit display often do not accept Quote Link to post Share on other sites
ricmarzola Posted April 7, 2009 Report Share Posted April 7, 2009 thankyou very much to GTIMatt and Slothy It worked for me too!!! Quote Link to post Share on other sites
