StadEMS3 Posted May 3, 2009 Report Share Posted May 3, 2009 This site is increadable! I cannot believe the things that you guys have done with these units. Well, as you can tell I'm another newb with two questions that i couldn't find on here. So, I'll ask the experts. I'm using the PAC C2R-FRD1 with my F90BT in my 2007 Explorer Sport Trac. I completed the hard bypass for mute/prarking brake and everything is soldered and shrink tubed. Looks nice if I must say so. Anyway- 1. Does the PAC blue/white amp wire get connected to the F90BT system remote control (amp) wire? I am not using exteral amps. 2. As I said, I did the hard bypass mod and realized the PAC CAN-bus has a red/white parking brake wire too. Does this wire get grounded along with the yellow/black mute wire and light green parking brake wire? Thanx! Quote Link to post Share on other sites
StadEMS3 Posted May 4, 2009 Author Report Share Posted May 4, 2009 Anyone, please? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted May 4, 2009 Report Share Posted May 4, 2009 1. If the PAC has a blue/white wire on it, CONNECT THEM. If not, there's no need unless you run aftermarket amps. 2. I'm not 100% familiar with the piece itself, but don't bother with the PAC pb wire. If it's what I think it is, that wire is only meant to give you the vehicle's parking brake to connect to the radio's (non bypass method) via CAN-Bus, and if you ground that your brake indicator will always be on. Cut it, tape it, forget about it. Quote Link to post Share on other sites
