Volumen very low when playing USB
Hi,
i have an AVIC-F900BT and my problem is that, hearing the radio, the volume is between 15 and 20, but if i want to listen to music from usb, i must set the volume around 30, is almost impossible to hear nothing with the same volume than the radio. I tried to configurate the settings, but everything is the same. What can i do? Thanks!!
Hi,
in your audio setting look at the sla and adjust it when you have your usb, SLA stand for sound level adjustment, same thing when your using an sd adjust at the sam level or maybe higher that what you have set on usb
