ludrof Posted June 14, 2009 Report Share Posted June 14, 2009 i need help, i tried to install this program after i figured out what to do, and everytime i try to access the i press the ok button to the warning screen before the map mode, the system starts itself over again like you are just starting up your car. what do i do to fix this issue. please help! Quote Link to post Share on other sites
ill.die.trying Posted June 14, 2009 Report Share Posted June 14, 2009 i need help, i tried to install this program after i figured out what to do, and everytime i try to access the i press the ok button to the warning screen before the map mode, the system starts itself over again like you are just starting up your car. what do i do to fix this issue. please help! install which program? Quote Link to post Share on other sites
ludrof Posted June 14, 2009 Author Report Share Posted June 14, 2009 it was a mod from that changes the way your gps screen looks. it is in the hacks/mods cat. and is labeled finally finished f700bt tweaks. Quote Link to post Share on other sites
ludrof Posted June 14, 2009 Author Report Share Posted June 14, 2009 i have made a backup, should i just delete everything that is in the flash-drive, and copy all of the original files. when i tried to delete them before, it says that deleting some of this files with make this program not run correctly. Quote Link to post Share on other sites
ill.die.trying Posted June 15, 2009 Report Share Posted June 15, 2009 i have made a backup, should i just delete everything that is in the flash-drive, and copy all of the original files. when i tried to delete them before, it says that deleting some of this files with make this program not run correctly. what unit do you have? Quote Link to post Share on other sites
jschatte Posted June 15, 2009 Report Share Posted June 15, 2009 Sounds to me like you have a poor ground. My assumption is when you start moving the ground is bouncing around causing the unit to reboot, becasue the ground is losing and gaining contact. I might be wrong, but it wont hurt to check Quote Link to post Share on other sites
