rheller1 Posted June 18, 2009 Report Share Posted June 18, 2009 I have a f700bt that works fine. However, I know at some point I am going to have an issue and will have to reload software on it. Here is where my problem starts. I have my SD card formatted to fat32 and then the test folders loaded on it. Put it in the slot, power on and all is fine...till copying files is done, then it freezes up. The screen stays the same, just cant do anything. I want to backup my files, but I cannot get to them because of this. I have tried this about 15 times now with no success...any ideas? Quote Link to post Share on other sites
ill.die.trying Posted June 18, 2009 Report Share Posted June 18, 2009 I have a f700bt that works fine. However, I know at some point I am going to have an issue and will have to reload software on it. Here is where my problem starts. I have my SD card formatted to fat32 and then the test folders loaded on it. Put it in the slot, power on and all is fine...till copying files is done, then it freezes up. The screen stays the same, just cant do anything. I want to backup my files, but I cannot get to them because of this. I have tried this about 15 times now with no success...any ideas? first off, what are you trying to do? if its your first time going to testmode then you have to calibrarte your screen first Quote Link to post Share on other sites
rheller1 Posted June 18, 2009 Author Report Share Posted June 18, 2009 my screen has been calibrated. What am i trying to do? Back up my files in case I need them later to reload Quote Link to post Share on other sites
ill.die.trying Posted June 18, 2009 Report Share Posted June 18, 2009 my screen has been calibrated. What am i trying to do? Back up my files in case I need them later to reload try this, go to my link and download the thelatest version, follow the instructions except for the copying of the files to the unit, once in testmode then make your back up Quote Link to post Share on other sites
rheller1 Posted June 18, 2009 Author Report Share Posted June 18, 2009 go to my link? Quote Link to post Share on other sites
ill.die.trying Posted June 18, 2009 Report Share Posted June 18, 2009 go to my link? http://avic411.com/forum/viewtopic.php?f=34&t=22695&start=570 Quote Link to post Share on other sites
rheller1 Posted June 18, 2009 Author Report Share Posted June 18, 2009 that worked perfect! Thanks! Quote Link to post Share on other sites
ill.die.trying Posted June 19, 2009 Report Share Posted June 19, 2009 that worked perfect! Thanks! no prob Quote Link to post Share on other sites
