MeksEvoX Posted June 22, 2009 Report Share Posted June 22, 2009 so ive had my f90bt for about a month now and just starting to "hack" it a little. now ive made copies and back-ups my "myflashdisk" like 5 times already. Im just trying to modify the "image.res" in the common folder of the adr. Can someone tell me.. 1) the size of the pics, have to be the same size as the original?, im using a serif photoplus software to modify the picture. file have to be .bmp format right? 2) the settings for the 7zip soft. set to "ultra" from the thread about 8-9 down.lol 3) do i have to copy the whole myflashdisk and just modify it from there and compress everything? 4) when i compress the file back down itll be image.zip and all i do is erase the ".zip" and type in ".Res" right? im pretty sure its all in the compression of the file. so if someone can give me a step by step on how to compress and extract file thatll be great. the problem that im having is itll start my splash screen and gets stuck. doesnt do anything. ive gone back and forth from the .bak and have put everything back to normal fine. can someone help me out please. thanks Quote Link to post Share on other sites
ill.die.trying Posted June 22, 2009 Report Share Posted June 22, 2009 1) the size of the pics, have to be the same size as the original?, im using a serif photoplus software to modify the picture. file have to be .bmp format right? 2) the settings for the 7zip soft. set to "ultra" from the thread about 8-9 down.lol 3) do i have to copy the whole myflashdisk and just modify it from there and compress everything? 4) when i compress the file back down itll be image.zip and all i do is erase the ".zip" and type in ".Res" right? im pretty sure its all in the compression of the file. so if someone can give me a step by step on how to compress and extract file thatll be great. the problem that im having is itll start my splash screen and gets stuck. doesnt do anything. ive gone back and forth from the .bak and have put everything back to normal fine. can someone help me out please. thanks 1)yes, yes 2)the settings does not matter, but i use ultra as it makes the alot smaller 3)just modify what you need, 4)yes zipping the image folder is kinda tricky as you have zip the image folder instead of just zipping it contents Quote Link to post Share on other sites
MeksEvoX Posted June 22, 2009 Author Report Share Posted June 22, 2009 So one out of four I'm doing everything right lol. Problem is how do I make sure my icons gets back to the same size, 112? And when I extract it, do I extra it within, into a file etc? Same thing when compress. Normally I just compress it into a new folder and change the .zip to .Reg. Quote Link to post Share on other sites
ill.die.trying Posted June 22, 2009 Report Share Posted June 22, 2009 So one out of four I'm doing everything right lol. Problem is how do I make sure my icons gets back to the same size, 112? And when I extract it, do I extra it within, into a file etc? Same thing when compress. Normally I just compress it into a new folder and change the .zip to .Reg. what i would suggest is using the exact same icon and just modifying it, also, does the software your using support channels, if so then you also have to modify the channels, if not, find a software that supports it like photoshop when extracing just right click the image.res and click extract with 7zip, then ok when compressing you have to right click the image folder and click add to archive then ok Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 arrrrggg this is hopeless. im not keeping the exact size i want. wonder if i can upload the photos and have someone work on it for me...*hint hint* Quote Link to post Share on other sites
ill.die.trying Posted June 23, 2009 Report Share Posted June 23, 2009 arrrrggg this is hopeless. im not keeping the exact size i want. wonder if i can upload the photos and have someone work on it for me...*hint hint* i'll do it, "hint hint" $ Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 well i figure out how to keep the files the same size but now when i compress it, it gets bigger. im close but not there. anyone ideas? to compress it i just go back to "image" and select "add to archives..." then it turns into "image.zip" then i change it to "image.Res" which turns into 1766k. Quote Link to post Share on other sites
ill.die.trying Posted June 23, 2009 Report Share Posted June 23, 2009 well i figure out how to keep the files the same size but now when i compress it, it gets bigger. im close but not there. anyone ideas? to compress it i just go back to "image" and select "add to archives..." then it turns into "image.zip" then i change it to "image.Res" which turns into 1766k. so what you mean when you say size is the space it's consuming not the dimension size, well if you modify your image.res then most probably it would be bigger, i thought we were on the same page, Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 The space after I compress everything back gets bigger. So my modified image.res becomes 190k instead of the original 112k, even though the .bmp that I modified is the same size. Quote Link to post Share on other sites
ill.die.trying Posted June 23, 2009 Report Share Posted June 23, 2009 The space after I compress everything back gets bigger. So my modified image.res becomes 190k instead of the original 112k, even though the .bmp that I modified is the same size. it doesn't matter Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 So it doesn't matter if the whole zip file change but the .bmp does? Weird. Anyways when I unzip it, it goes image>image do I compress the first image or the second? I do appreciate all the help I'm getting and can get. All I want to do is change these 3 simple icons!lol. Such a pain. Quote Link to post Share on other sites
ill.die.trying Posted June 23, 2009 Report Share Posted June 23, 2009 So it doesn't matter if the whole zip file change but the .bmp does? Weird. Anyways when I unzip it, it goes image>image do I compress the first image or the second? I do appreciate all the help I'm getting and can get. All I want to do is change these 3 simple icons!lol. Such a pain. i can't exactly remember which one should be compressed, try creating both and then try loading them and see which one works Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 Yeah I give up! Tried like ten times. Different compression, redoing the.bmp, . Nothing. Quote Link to post Share on other sites
ill.die.trying Posted June 23, 2009 Report Share Posted June 23, 2009 Yeah I give up! Tried like ten times. Different compression, redoing the.bmp, . Nothing. send me the finished pics and i'll help you out Quote Link to post Share on other sites
MeksEvoX Posted June 23, 2009 Author Report Share Posted June 23, 2009 Yeah I give up! Tried like ten times. Different compression, redoing the.bmp, . Nothing. send me the finished pics and i'll help you out thanks a million. tell me if you can get the files icons.zip Quote Link to post Share on other sites
