shaft412412 Posted July 3, 2009 Report Share Posted July 3, 2009 I uploaded the new update 2.006 and now need to reload the file to bypass the speed sensor. in the old date zip file it was under project_config. But i do not see this file in the new data file on the f90. Is there somewhere else i'm suppose to put this file or what. any help would be great. thanks Quote Link to post Share on other sites
ls2009 Posted July 29, 2009 Report Share Posted July 29, 2009 I'm having the same trouble since loading the update (2.006) also the bypass doesn't work when trying to watch a movie while moving now. On my f900bt . Have you found out anything I sure could use the help. Thanks L. Quote Link to post Share on other sites
ekrboi Posted July 29, 2009 Report Share Posted July 29, 2009 this software bypass is cool and all but just do the hardware bypass its almost easier if you know how to take your unit out of your dash than copying the files.. and it will always work no matter what.. there is a post on here with pictures.. it doesnt require taking anything apart.. just switching the yel/blk mute wire that never gets used to another spot and grounding it and the park brake lead.. Quote Link to post Share on other sites
